Looking for some info on swapping bravada transfer to blazer
I have a 1999 Oldsmobile Bravada and the transfer case is binding up like they do. I will have to swap out out the t case. I am going to swap it with a blazer with selectable 4x4. I have a parts truck I can take everything I need from. What will I need to change modify or make? Anyone done this before
For starters you'll need several wire harnesses, switches, drive shafts, possibly a PCM & BCM, but definitely at least a reprogram, TCCM, front axle actuator.
thanks
My bravada is just to clean to sell because of the issue and I want it to look good I want to lift it. And I want to get rid the AWD I hate it. I need to tear it apart and figure out what I have to work with and the differe nces
kempo
want to sell the diff and t. case? Im thinking of going the other way, to awd. I would need driveshafts and any computer parts to control. Anyone done the conversion to awd? I' d like to chat with someone who has gone thru the conversion. By the way, ive got a 97 blazer , but I think I would like to use 98 and up components. thanks
| All times are GMT -5. The time now is 11:49 PM. |
