Modifications for better mpg
I have a 2001 blazer with the 4.3l it's getting bout 10-13 mpg i have to drive 60 miles back and forth to work and this ads up quick at the pump. I dont want to have to go buy a gas saving car because i like having a 4x4 vehicle so does anyone know of any cheap and easy mods to help increase it to get closer to 20 mpg?
Give it a solid tune up, make sure your tires are properly inflated, don't add any accessories that will diminish aerodynamics and most of all over everything change your driving style. Accelerate slowly and keep it below 60mph. I've seen people claim 20mpg but never seen it myself.
(Post 670298)
Hate to say it but if your doing 80 your not going to do much better than what your doing now. These things just aren't made for high mpgs.
Are there anyone doing tunes to increase mpg/driveability
(Post 670298)
I can get 20+ but only on a straight level road at constant 60mph with no A/C - very rare to go very far this way but I have done 80 miles at 22 mpg and filled up just to test MPG. Average driving I get 14.5 - 15.5 mpg for 50:50 city/country roads with no traffic to speak of, just some stopsigns and stoplights - max 45-50 mph. If I do a round trip to Chicago O'Hare (about 240 miles RT) on the Interstate at 70 mph, I expect to see maybe 18.5 max if no A/C on and make it back without filling up. I check true mileage at each fillup with fuel. Drive with instant MPG displayed on Android Phone scanner like Dash Command or Torque Pro - it will definitely teach you how to drive. I try to keep TCC locked up whenever possible (hit the magic 47 mph and keep the foot out of it). A/C will lower 1-2 MPG. TCC engaged will raise a couple MPG. It will cost you a lot to keep up with all the speedy people who drive 70-80mph. Pushing a box through the air at 80mph takes a lot of power, as does changing the speed of a heavy vehicle. |
Is you SES light on? You could be constantly driving in open loop which will run very rich, especially under load, if your system detects a fault with any of the O2 sensors and switches the system to always run in open loop. This is probably the most common reason people mpg drop (assuming they've done a good tune up, etc).
I have had non stop problems from the o2 sensors and emissions as of right now check engine light is off
I got 15 mpg. Installed headers, CIA (for what its worth) new o2 sensors, Accel 48,000 volt coil ( stock is 40,000) 8.5mm wires and had the computer tuned. Now i get 17mpg.
you can do the throttle body mod. it helps with throttle response and some say helps with mpg.
| All times are GMT -5. The time now is 12:00 AM. |
