Bassically_Bravada |
10-24-2013 06:25 PM |
MSD Blaster Ignition Coil issues!
Well this is my first post here so bear with me and critique me if i screw something up. Well I put in an MSD Blaster Ignition coil hoping for some better performance and MPGs. Well it ran fine when I installed it but when I was leaving my job, it bogged down a little bit and than ran fine. Then it died in another parking lot. When I got it going again, it lurched like when you don't shift completely right in a stick shift. It says it is a high voltage coil so is it pulling too much current from my already weak battery that might be on its way out. Or did I make some sort of rookie mistake?
Thanks in advance
