-   Performance & Brainstorming (https://blazerforum.com/forum/performance-brainstorming-38/)
-   -   Want more power, what to do? (https://blazerforum.com/forum/performance-brainstorming-38/want-more-power-what-do-66219/)
2000Bansheeboy Dec 22, 2011 01:26 AM
So I'm at kind of a plateau right now with power. My K10 has a goodwrench crate motor with longtube headers (dont know what), custom dual side pipes with hi-flow cats, edelbrock hi-rise intake with a holley 680cfm offroad carb. What's left? I want some more power! Help me out a lil bit and give me some mods that aren't going to be 2grand each.
pj5454302 Dec 28, 2011 10:22 PM
I see you have 35's so what are you running for gears?
If you havent messed with them and you pick up a set of 4.10's or 4.56's you would pick up some power.
chris015 Dec 28, 2011 10:25 PM
yep,if you have yet to regear for those tires do so! some 4.56's would help a ton with the feeling of power.
put in a mild cam,and edelbrock performance intake,then tune the jets in the carb.
2000Bansheeboy Dec 29, 2011 04:49 AM
I actually don't know what gears I have. I put in a newer dana 44 in the front which clearly has different gears in it because it lurches like nuts in 4x4 now so I dont use it. He said it has 4:10s. I'd like to know what gears I had in it before so how can I ID what's in the old axle?
And what cam do you guys think would be good on street, dirt and mud? And I already have an eledbrock performer intake.
pj5454302 Dec 29, 2011 07:20 AM
In your glove box you can look at the rpo codes, or take your vin to a dealership and have them look it up. Otherwiese you can pull off the diff cover and it will have the ratio stamped in the ring. Also for your set up I would go with 4.10 if its driven daily, but if its a saturday night crusier/fun in the mud avery now and again I would go with 4.56
chris015 Dec 29, 2011 10:05 AM
well now you MUST regear both to be the same,or say goodbye 4x4. regear to 4.56.
2000Bansheeboy Dec 30, 2011 12:19 PM
I knew I had to regear, I had to use it anyways once or twice to help me get out of mud pits but otherwise, it hasnt been used. And it is my daily driver, so is 4.10 lower than what I probably have? I have a feeling it has stock gear ratios. Also wanted to maybe look into a posi rear end, any suggestions on where to find the stuff?
Xenon Dec 30, 2011 04:27 PM
IIRC 3.73 should be stock in that.
In your glove box, look for the "Service Parts Identification" label with all the RPO codes on it.
Code "GT4" is for 3.73, "GT5" is 4.10. IIRC "GT8" was also sometimes used for 4.10...
There is more than one code for 3.43 though... dont remember what they are...
It could also be as high as 3.08, which would really suck with 35s...
2000Bansheeboy Dec 31, 2011 06:42 AM
Well it can't be too high since my granny gear (it's a manual) gets me up to pooosssiiibbbllyyy 10mph.
duxtoyz Dec 31, 2011 10:18 AM
id put 4:56 in it, posi rear end, k & n filter, remove the cats, and a msd ignition box. they are "cheap"....a 6a would work. ul tell a difference with just the msd and gears alone.
