Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
what are the best mods before tunning my pcm
Old Nov 18, 2012 | 12:51 PM
Diaita's Avatar
Thanks! It cost me around $2800 in parts for axle, steering and drivetrain. Lift was about $120.
Old Nov 18, 2012 | 01:00 PM
cali bear 87's Avatar
cali bear 87 is on a distinguished road
Now in this case I should have saved my money I spent around 1300 on wheels and rough country kit I need to save for that axle swap, hows the ride feel on that and is it slower
Old Nov 18, 2012 | 01:20 PM
Diaita's Avatar
It rides firmer than stock for sure. About the same as an xterra or trd Tacoma. It handles far better than with the 5" trailmaster lift I pulled out. It has to be slower than stock,I've added a fair bit of weight. Mileage isn't bad, about 9 mpg in town, 19 on the highway.
Old Nov 19, 2012 | 08:02 AM
You wouldn't happen to still have trailmaster lift would you
Old Nov 19, 2012 | 12:10 PM
Diaita's Avatar
no, sorry. it sold really quick. I wouldn't buy a TrailMaster lift for an S series again. It was decent overall, but it had poor steering geometry, and a little hokey how some of it was done.
If you want a lift, a SAS really isn't too hard, just time consuming.
Old Nov 19, 2012 | 08:32 PM
That's what I do want but like you said time consuming, I need to finish my other project first because the blazer is my daily driver I think I might start hunting down piece by piece, what trucks would be donors for the axle swap?
Old Nov 19, 2012 | 09:35 PM
Diaita's Avatar
it all depends what you want to do with it, how hard you want to drive it and how you fabrication skills are. Cherokee axles are really popular, have good aftermarket support and are the right width. Best of all usually cheap and easy to find. The down side is they are somewhat weak, only the front is a better axle is an s10. I thought about using a couple full width Ford axles a Dana 44 and 9" rear axle, a bit wider, but could work and are pretty tough. The 95+ explorer rear axle is good if you want a decent axle with disc brakes.
I chose my axles because there was nothing bolt on about it...completely custom.
Old Nov 20, 2012 | 11:45 PM
And what about the t case
Old Nov 21, 2012 | 03:03 AM
Diaita's Avatar
You'll need to change out the front output shaft on your transfer case so you can install a standard or CV(preferred) yoke. a late 90s to 2000s cherokee works ok as a doner so long as it has the wide chain. 95 and earlier blazers all had the wide chain and a standard yoke.
Old Nov 21, 2012 | 09:02 AM
Thank for all the info now I just need to start hunting down parts on the bright side its almost new years so pretty soon it'll be tax return season
maverick_4x4
Engine & Internal
15
Nov 8, 2015 12:44 PM
Jimmy_Blazer
Jan 12, 2013 08:48 PM
Alablazer
Mar 1, 2012 02:25 PM
Spectreblazer
Mar 20, 2010 03:36 PM
4lowlife
Engine & Internal
13
Jun 14, 2006 03:10 PM
