Where can I get a reman MFI FJ503
I have bought 3 Spider injectors (Amazon) for my 04 Blazer 4.3 L and they started leaking from the body after a couple weeks. I can't afford a new one and to be honest I have not had much luck finding anything that didn't say "backorder" or "sold out".
I did take one of the fuel metering body and plastic welded it then put it back together with parts from a couple different MFI that I couldn't return. The leak down was very slow. And I think it is the fuel pressure tester itself because I found no gas. I am going to put it on but I want a decent remanufactured OE that has been tested. Heres the video of the last one. You can not see any signs that there is a major crack when inspecting it even with a jewlers loupe. https://youtu.be/Q54hlzcv7mg?si=5DDmqCGlUGxG4dWR Thanks |
Originally Posted by Blaz_r
(Post 752147)
I did take one of the fuel metering body and plastic welded it then put it back together with parts from a couple different MFI that I couldn't return. The leak down was very slow. And I think it is the fuel pressure tester itself because I found no gas. I am going to put it on but I want a decent remanufactured OE that has been tested. Heres the video of the last one. You can not see any signs that there is a major crack when inspecting it even with a jewlers loupe. https://youtu.be/Q54hlzcv7mg?si=5DDmqCGlUGxG4dWR Thanks I have not purchased anything from them, but I did find their info on the conversion some of us can do with our fuel injection systems pretty useful. |
(Post 752229)
Have you tried here: https://www.motormanfuelinjection.co...-injector.html
I have not purchased anything from them, but I did find their info on the conversion some of us can do with our fuel injection systems pretty useful. BEWARE to anyone reading... DO NOT BUY SPIDER INJECTORS FROM AMAZON. Thanks again Christine. |
I wanted to update this post. I had such problems buying the infamous spider injector for my 04 Blazer I think its incredible that I took parts from 3 separate units to make one working injection system.
The problem every time was the fuel meter body had imperceptible leaks you would never find even with a magnifying glass. So I used the OEM housing and found enough working injectors from the original spider and a different newer unit I didn't return in time. I call it the FrakenSpider and it still runs with no codes for 3 months now and to me thats amazing. If you seen how I canabilized then reassembled one good working unit. Its actually a fairly basic system and all the parts are interchangeable just make sure the seals are good and clean thats the most critical part. And have patience pulling the port flutes out that can be a bugger of a time. Before you go and pay hundreds of dollars on an oem or oem rebuild just rebuild and clean it yourself its not difficult or technical. Good luck. |
(Post 753434)
The problem every time was the fuel meter body had imperceptible leaks you would never find even with a magnifying glass. So I used the OEM housing and found enough working injectors from the original spider and a different newer unit I didn't return in time. I call it the FrakenSpider and it still runs with no codes for 3 months now and to me thats amazing. If you seen how I canabilized then reassembled one good working unit. Its actually a fairly basic system and all the parts are interchangeable just make sure the seals are good and clean thats the most critical part. And have patience pulling the port flutes out that can be a bugger of a time. Before you go and pay hundreds of dollars on an oem or oem rebuild just rebuild and clean it yourself its not difficult or technical. Good luck. :icon_beerchug: |
| All times are GMT -5. The time now is 12:47 AM. |
