Calling All Lifted Trucks!
Old 12-08-2018, 02:19 PM
2.5 rough country lift
add a leaf kit in the rear
zr2 fender flares
zr2 tire carrier
brush guard
rear tail light covers
Camaro rims on 235/75r15 summer
stock s10 offset 235/75r15 winters
side steps in storage waitting for a welder.
  #492
Old 12-10-2018, 10:53 AM
christine_208 will become famous soon enough
Here's my modestly lifted truck. Details below.
Mods to do:
  • Install hidden front receiver behind licence plate so I can mount a portable 9,000 lb winch on the front or back
  • Upgrade charging system for winch
  • Install HD 1-ton idler arm bracket and idler arm parts
  • Install exterior spare tire carrier
  • Install brush guard
After a day of deer hunting last fall.
  #493
Old 12-10-2018, 11:30 AM
Originally Posted by Nicky Petrillo
how do you lift a truck? I would love my truck higher,with bigger off road tires...i have a 97 chevy blazer...
what kind of shop does this kind of work?
I'm sure you can get a quote from any local shop. But itll probably be cheaper for you to buy your lift kit online, and then bring it to them to install. It is not too hard to do. I was able to do all my work/maintenance in my driveway. Be prepared to pay anywhere from 5+ hours of labour pending on lift kit.
  #494
Old 12-10-2018, 12:33 PM
There are suspension-lifts that provide more clearance for obstacles and allow for adding larger tires (that also add to the clearance) and then there are body-lifts that do not help with road clearance but do aid with providing more room for larger tires.
Suspension lifts mostly consist of replacement of key suspension components. The Rough Country 2.5" suspension lift kit is a good example. Sometimes people also replace the front independent front axle with a solid axle. I wrote up what I did for my lift here: https://blazerforum.com/forum/builds...on-lift-95744/
The body lift consists of adding spacers between the body and frame so that the body sits higher. This I have never done but I would think there are challenges with the steering wheel shaft, electrical connections, and fuel tank filler hose to name a few. I have seen where some would do a body lift purely for the looks. I did my mild suspension lift for purely practical reasons. What you do depends on your goals and the expected uses for your truck.
Most shops can do this type of work but ask around for which ones could do it and what they would charge before buying any parts. Most people do these modifications, at least the suspension lifts, themselves in their garages or driveways.
  #495
Old 01-10-2019, 07:26 PM
cleburne red's Avatar
6" Rough Country Lift
Pro Comp rims, 15x8, 4.5" backspacing
33x10.50 super swamper boggers
  #496
Old 01-21-2019, 08:28 AM
bajablazer93's Avatar
bajablazer93 is an unknown quantity at this point
2.5 rough country lift, 2 inch body lift running on z28 aluminum wheels wrapped with some 32s
  #497
Old 02-02-2019, 08:19 PM
Madson26's Avatar
Madson26 is on a distinguished road
Close to where I started or say stage 1. SL6 and 33's, broken parts weekly
tired of breaking parts in the front end, now I break other stuff lol. SAS D44/D60 and V8 on 37s
  #498
Old 02-14-2019, 12:31 AM
BritishColumbiafishing is on a distinguished road
2.5 rough country with steel braided brake.lines slid plated running cooper stt pro beating her in british columbia Canada Eh
  #499
Old 03-10-2019, 03:06 AM
Mike.308's Avatar
Originally Posted by GeorgesBlazah
6in Superlift
2in Body
34in Tires
Guys and lads! Could anyone help me identifying these rims? They look just awesome!
@OP Do they match the Blazer hub mount, or You had to use adapters?
  #500
Old 03-10-2019, 09:35 AM
Madson26's Avatar
They look like GMC Sonoma zq8 wheels. If that's the case, they will bolt right up. No adapter needed
Quick Reply: Calling All Lifted Trucks!
