Did a body lift, what about the back bumper???
I did a body lift on my 95 Jimmy 4 door. Got the front bumper up, but the kit said the rear could be done with stock brackets. I looked at them and I wonder how the heck am I going to do that? It looks like I'll have to either modify the bumper or brackets or make new brackets. Any suggestions from anyone who has done a BL on a 95???
Originally Posted by Jimmy_Blazer
(Post 532440)
You have to drill a new lower hole in the bumper bracket and the original lower hole is now the upper bolt hole. You also have to trim some off the bottom of the bumper so it will fit around the frame cross member. The trimmed portion is not visible once the bumper is mounted unless you lay underneath the truck. If you do it carefully you can't really even tell the difference on the bumper from stock vs. lifted.
When drilling the new hole in the bracket make sure you get the spacing perfect because the two bolts are attached together and you will have a hell of a time if its a little off. or just drill a bigger hole.
