Please rate my tweeter install.
Got my first set of components.
I decided to mount the tweeter close to the woofer so it sounds like it's coming from one place. How does it look? Is there some gray paint I can get that won't clog the vents on the tweeter? http://s2.postimage.org/29vpt69t0/1304833455335.jpg http://s2.postimage.org/29vwfbns4/1304833423052.jpg |
i no stereo expert...but it looks like a good clean install to me.
as far as paint do several very light coats and you should be fine. |
Originally Posted by warthogdriver
(Post 431174)
as far as paint do several very light coats and you should be fine. Trying to keep it as stock as possible. so far this is now the only thing I can't un-do, but it's an upgrade. I don't see how anyone wouldn't want this... |
looks good.
where did you put the cross over box? |
Looks great. ^^please don't say in the door :(
Originally Posted by rodono
(Post 431192)
Originally Posted by zedartwo
(Post 431204)
in the door... There is a ton of room back there. Where else should I put it? |
Its not about room. They are very sensitive and not water tight. Any water gets down there and your crossovers are shot! I suggest either where the center console meets the firewall or somewhere else out of harms way of feet and water.
(Post 431216)
I was thinking about putting it somewhere behind the door panel if there is room. |
How's this?
http://s2.postimage.org/2b5sl7d44/DSCN9318.jpg http://s2.postimage.org/2b5u8qplw/DSCN9319.jpg Edit: this is the final outcome. Perfect fit. I even got the mids to fit perfectly in the door and don't stick out now. Now I wonder if I can put those 3" full ranges..at least I think that's what they are called. I always see 6", 1" tweeters and then a 3" speaker. http://s1.postimage.org/22yqf0wzo/DSCN9322.jpg http://s1.postimage.org/22ys2k9hg/DSCN9323.jpg http://s1.postimage.org/22yn3y804/DSCN9320.jpg http://s1.postimage.org/22yorhkhw/DSCN9321.jpg |
I'm not a huge fan of where they are. I know its a PITA but try inside the cab. No water can TOUCH them let alone have a chance to ruin anything.
