tires and pics
got my tires!!!! rubbed once in daily driving but i was driving way uphill and turning s on 4 doors yes 31's will rub but im doing som fender trimming and trying that one again should be a winner!!!! commnts appreciated ,,,
[IMG]local://upfiles/4554/0C244094E811465D9A21BFDC15C9712E.jpg[/IMG] |
RE: tires and pics
Looks nice man, by the way, did you seal your frame or somthing?
RE: tires and pics
truck bed liner all the way under neath aything i could reach even under my fender flares rear end plus new chrome diff cover (last install)im gettin there on it finally aftera whole frond ent two new rims a jasper tranny rear axle and some new tires. truck bed liner seems to work better under than anything i have tried it sticks to anything even rubber anyone know any place to take m truck to get re-programmed
RE: tires and pics
You should just be able to bring it to the dealer to get it re-programmed. How hard was it to change the diff cover in the rear? I use undercoating that is made to be used under your truck for the frame. I have seen to many older blazers with rusted frames, so before it started rusting I decided to spray every metal piece under my truck. Took 4 cans of it, but everything is coated now (except for anything that gets hot). I even took the tires off and gave the a-arms a full coating.
RE: tires and pics
Looks real nice sittin on the 31s. As for the rubbing, just give your T-bars a little crank up and you should be fine. Mine rubbed at first, but I did that and they don't rub at all.
RE: tires and pics
Yup, looks good. It's amazing how a set of tires can change the look of a truck so much.
