02 ZR2 want to clear 32's
Stock 2002 ZR2 Blazer with 31's sags in the rear a bit maybe weak leafs?
The daystar 1.5 and fabtech 2.0 shackles from synergyoffroad.com Are these shackles bigger than the stock zr2 shackles? If 1 of them will raise it up a bit in the back and t bar crank in the front I'm thinking 32's will fit nice. Also what about shocks, should bigger shocks such as the 2"superlift shocks on synergy be done to replace old existing stock blisteins? Any help or reccomendations would be apprtiated. |
Sagging leafs? Sounds like a good excuse to get an "Add a leaf" to get your clearance.
I clear 33's with an add a leaf, t-bar crank, and a small bit of trimming of the front bumper.
Originally Posted by Logan
(Post 363576)
thanks for the info.
Still wondering if I need the extended 2 inch lift shocks they have there at synergy to make up for the shackle/leaf and crank raise |
Will I clear 33x 12.5's with 2 inch body lift longer leaf shackles t bars cranked and add a leafs on my 2000 zr2 blazer?
| All times are GMT -5. The time now is 04:47 AM. |
