-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   1999 Chevy Blazer 4x4 Rear Axle Assembly replacement (https://blazerforum.com/forum/steering-suspension-drivetrain-36/1999-chevy-blazer-4x4-rear-axle-assembly-replacement-103076/)
MikeBilak 03-01-2021 10:08 AM
I need to replace rear axle assembly on son's 1999 Chevy Blazer 4x4 (Base trim) GU6. Will a rear axle assembly GU6 from 1999 Chevy Blazer 4x4 LS or Limited trim work? I have looked at several photo for rear axle assemble listed for 1998 to 2003 Blazers GU6 and all of then show different mounting brackets setups welded on the rear axle housing that look nothing like the one we just removed.
Any information would be greatly appreciated.
Thank You
DonL 03-01-2021 11:58 AM
Same rpo gear code and 4x4 is what your looking for, also if you find one with a g80, that helps.
DonL 03-01-2021 11:59 AM
Can you post pics of the different mounts you mentioned? Just remembered you wrote that.
Tom A 03-01-2021 12:02 PM
I don't know if it will help you, but here's a picture of the rear axle I took out of my 2000 LT.
https://cimg8.ibsrv.net/gimg/blazerf...77d8dbaec5.jpg
DonL 03-01-2021 12:05 PM
Looks the same as my 99, so if it looks like that, then your good.
MikeBilak 03-01-2021 03:07 PM
Thanks to all that responded.
I got all the information I was looking for. Found a rear axle assembly from a 2000 Chevy Blazer LS 4X4 (GU6) with 113K. The one we removed from vehicle has 256K.
Thanks again.
