-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   2001 Blazer 4x4 banging sound (https://blazerforum.com/forum/steering-suspension-drivetrain-36/2001-blazer-4x4-banging-sound-90277/)
jcecampbell Jul 19, 2015 05:03 PM
I'm glad to find this forum! I bought my blazer about a month ago. It has 196k miles on it. I put new shocks on it right away, and plan to buy new front axle shafts, hubs, tie rods, pitman arm, idler arm, and bearings tomorrow.
The problem is, every time I drive over gravel or rough road, I get a loud, repetitive, banging noise from the front right wheel. I have side to side movement of the wheel when off the ground, and the stabilizer bar links are worn out on both sides.
Would ball joints cause this?
CWBDDSPC Jul 22, 2015 06:13 PM
I would say if you are replacing all of those items, you may as well do the ball joints too. Banging could also be from control arm bushings. I would add axle shaft seals to your list as well. I would hate to have to tear everything down again for a couple seals...
( and don't forget the alignment;) )
