2003 4WD alignment
Old May 8, 2012 | 01:34 PM
03BLZR4WDV6's Avatar
03BLZR4WDV6 is on a distinguished road
Default 2003 4WD alignment
need help determining alignment for 2003 4WD V6 Chevy Blazer
-pulls to left(drivers side) while driving/cruising
-excessive wear on outside driver's side tire
-replacing upper & lower ball joints helped correct the problem but still pulls to the left(driver's side) quite a bit
-tire pressure exactly the same on both sides @36psi
-brake pads have even wear & don't seam to have much affect on pull
I was hoping to make a minor adjustment to the toe-in as temporary fix...
how can I tell if it's the idler/pitman arm as the cause?
is there anything else to check in determining the source of problem?
Attached Thumbnails 2003 4WD alignment-bzr-006.jpg   2003 4WD alignment-bzr-005.jpg
blazen_red_4x4
Oct 13, 2014 12:39 PM
oneton77
Jul 2, 2010 10:21 AM
Jisher
Feb 27, 2010 02:15 PM
ronkrolock
Jun 11, 2009 06:17 AM
guitarman
Lowering Tech
Mar 16, 2008 12:29 PM
