2011-2013 Camaro brakes
Ok so I have a 2000 2wd 2door blazer 4.3. My question is will the new style camaro brakes fit the front of our blazers. Only reason I ask is I know a guy selling a set of wilwood 4 piston calipers dirt cheap never been on the car.... Brand new. They have brackets but it does not look like they bolt on the same as ours. Thank you for any input guys! 👍😬 sorry if this is in the wrong section
If your spindles have a bolt on caliper it will work with an adapter. See my user bio page for vette brakes inside 2011 camaro 18 inch wheels. If you have single piston calipers with a C frame spindle Its prolly more trouble then its worth
Tried going to your page but had nowhere for the bio page. Sorry still trying to figure out the site. These calipers are actually camaro calipers not vette. Are they the same calipers? I have the newer style spindles so I know the C6 calipers will work just wasn't sure on the camaro brakes? 😕
Your not dealing with a ford here. It will work and work good. I can send you a dxf or agis of the adapter if you want. Mounting points for C5 and C6 are the same but the rotor is a little less than half inch bigger.
Hahahaha thank god!!!! That would awesome if you could! Thank you
i know that older camero rear ends will fit on blazers they bolt right up my 2000 blaze has 02 SS camero rear end 4 link and while i had it out i when ahead and pulled the tired 3:73 gears out and put 4:10s in, love the disc brakes for sure specially when i got my daughter in the blaze but could never get the abs light to go off after:)
Where to send it and in what format
