-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   2wd Upper Control Arm Removal Issue (https://blazerforum.com/forum/steering-suspension-drivetrain-36/2wd-upper-control-arm-removal-issue-87314/)
BIGJEFF64 09-26-2014 03:32 PM
I have tried to remove the 2 bolts that hold the control arm assembly to the frame 2 separate times no i have soaked them in PB blaster, tried using a breaker bar and they will not budge!!! does anyone have any idea?? i dont have access to air tools unfortunately or i would have tried that. Ultimately i need to replace the upper and lower bushing so if someone has done this on a 2wd please tell me how to get this done. thanks
chris015 09-26-2014 04:54 PM
its fairly simple.the head of the bolts have a square flange on each one to keep them from backing out...
try removing from only the nut. if they wont buldge try some heat. hit up walmart etc for a yellow bottle of map gas. its hotter then propane,propane wont do it. get em hot,and go at it.
10-78 edac 09-26-2014 11:09 PM
And keep the fire extinguisher handy. Heat and beat wins every time!
BIGJEFF64 09-27-2014 07:06 AM
I haven't tried heat so that's my next step thanks and do I need to do something with the flange or just work on the nuts with heat?
05canjimmy 09-27-2014 07:47 AM
you have to get the nuts off. then you gotta beat those bolts trough the bushing
BIGJEFF64 09-28-2014 07:35 AM
The bushings are so bad I don't think that will be as much of a struggle. The real pain is gettin these off the truck then tryin not to bend the arms. I have read these aren't the strongest control arms out there
