35mm sway bar?
I need a new front sway bar because the link hole is egg shaped on my 99.
I went to the junkyard this weekend and grabbed one off a 2002 blazer. Got home...measured it for new bushings... It is 35mm (34.9 with digital caliper) so it is 1.375" \ 1 3/8" \ 35mm problem is on Rockauto, the biggest sway bar on a blazer seems to be 33mm\1 5/16" any one run in to this before? any one know what bushing to frame to get? Thanks! |
I have seen multiple diameter listed for the same vehicle
check the year it came off of to see if they list different sizes , part numbers Not sure if the strap mount is different or just the bushing |
Thanks for the reply rexazz2
I have the straps and bushings from the junkyard one. Bushings are bulged and oil soaked. I can't figure out were to get bushings for this sway bar though. I checked the year it came out of. Rockauto doesn't list bushings this big. |
for what you might save on them , I would probably just buy them local
cant remember the last time I changed a set @ the frame , so dont remember how much the tighten down on the bar here is a moog link with dimensions Moog Suspension Parts - Universal Sway Bar Bushings |
BTW
they list 1 5/16 on the RWD in 2002 |
Thanks bud
Ended up not being able to use it.
Thread can be closed. Thanks |
| All times are GMT -5. The time now is 05:56 AM. |
