4 hi engaging for no reason
Hi Im new here I just bought a 98 blazer ls 4wd. I have a problem, for no reason it will shift into 4hi. I searched but couldnt find anything. There is nothing that seems to trigger it, its hapend on the highway, parked and in a parking lot. Anyone have any ideas? maybe a faulty switch?
I ordered a new 3 button switch. can I use the 4 button? I wonder if the 3 button switch doesnt work if I should try the 4 button, incase some one switched out with the wrong part. Or do the swithces have differant connectors?
If you have the NV233 transfer case, you cannot use the 4-button switch. They are not compatible with each other.
To determine which transfer case you have, you can either check the tag on the back of the transfer case for the model # or check your RPO codes. NP1 = NV233 (3-button) & NP8 = NV236 (4-button). If you do not trust the RPO code sticker in the glove box, put your VIN into the VIN Decoder at CompNine.com.
Check out this thread (and the ones linked to at the top):
NV233 No Mode Switch (ie. 2HI to 4HI)
This should help you narrow down the problem.
seriosbrad
Nov 7, 2015 09:08 PM
Jason Collins
Mar 23, 2012 07:55 PM
Blindthieves
Feb 4, 2007 04:22 AM
