Community
Search
4lo engaging by itself
Old 01-08-2012, 11:24 PM
01trlblzr is on a distinguished road
Originally Posted by mjt View Post
I dont think you ruled out a bad TCCM. You ruled out the switch and the connection corrosion. So you actually opened up the TCCM and made the measurements at F14 and F16 on the TCCM pc board with the connector plugged in? I havent tackled the vacuum problems yet but I can tell you there are a few vacuum lines by the power steering and ABS that were totally disintegrated on my 99. One of them actually supplies that vacuum switch on the firewall. It tees off and a line runs into the truck. You might take a look at those hoses for your vacuum problem. I bought used TCCMs at the junkyard when I got to about where you are. I ended up buying and returning several TCCMs til I got one that worked. All of them had corrosion at the connector. The TCCMs get wet from the vent you said is not functioning. That vent is located just above the TCCM harness. You can see it thru your glove box.
ok. i might take it to my cousins mechanic and see if he can firgure it out. hes a gmc master...sumthin. lol. if not ill try swapping out the tccm. i did take a look at those air lines in the past and noticed there a bit crusty but i didnt notice any air leaking. i might trace the hose that goes into the fender and look deeper. i might just cut my losses and replace all the air line. its prolly pretty cheap.
seriosbrad
11-07-2015 09:08 PM
emokihana
04-16-2013 06:48 PM
tmoble
12-21-2011 10:58 PM
dusted800
04-08-2009 09:20 PM
derby66
12-02-2007 12:54 PM
Quick Reply: 4lo engaging by itself
