4WD to 2WD engaging problem
Old Feb 20, 2009 | 09:05 PM
tarus420's Avatar
tarus420 is an unknown quantity at this point
Default 4WD to 2WD engaging problem
I have a 1998 S10 Blazer that is having a problem shifting back into 2WD from 4HI. It takes about 30 to 45 seconds to engage back into 2WD, but when it does it makes a thud sound. The faster I'm traveling the louder the thud. At 30 miles an hour it sounds like I hit a pot hole or a speed bump. Any suggestions?
Old Feb 20, 2009 | 09:31 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: 4WD to 2WD engaging problem
You have either different sized tires front to rear, or otherwise. Or a severely worn tire or low tire pressure...
Old Feb 20, 2009 | 10:27 PM
tarus420's Avatar
I do have a different size tire on the drivers rear. A couple of months ago I had a flat and put the spare on which is 235/70R15. The rest of the tires are 235/75R15's. The blazer is in need of new tires anyway so tomorrow I will try this. This makes sense.Thank you for the input.
Old Feb 21, 2009 | 03:05 PM
tarus420's Avatar
lastcoupe
I put some new tires on today and that's what the problem was. Thank you
Old Feb 21, 2009 | 03:17 PM
lastcoupe's Avatar
No problem guy, glad to help!
seriosbrad
Nov 7, 2015 09:08 PM
BlueRhino
Jan 28, 2015 06:14 PM
Doverman454
Nov 29, 2008 01:45 PM
zombiebebop
Engine & Internal
Dec 8, 2006 03:15 PM
Jeremy_87_S10
May 22, 2006 10:16 PM
