4wd problem
Old Jul 5, 2011 | 03:39 PM
614blazer's Avatar
614blazer is on a distinguished road
Default 4wd problem
i have a 1998 blazer lt 4x4. and my 4wd acted up well first i replaced my tranny and two days later the vacum hose to the 4wd burned up. and i left it like this for a month and 4wd worked but then acted up. but the other day i went to put it into 4hi and it engaged but when i try to put it back into 2hi it wouldnt disengage. all i heard was a clicking noise from the the control modual on the pass kick panel. so i was stuck in 4wd. and i needed to get it into 2wd. so i unpluged the control modual and no luck so i unpluged the eletric connector to the transfer case and it went back into 2wd. so i pluged the transfer case back in and its fine now. but i kept the control modual un hooked cause i dont want it to go into 4wd unexpected. what is causing my 4wd to be stuck in 4wd. i have the three button switch nedd help asap thanks
Old Jul 5, 2011 | 03:43 PM
xgiovannix12's Avatar
Look in the 1st link on my signature and there should be a thread called 4x4 no worky
that should have all the information you need
Old Jul 5, 2011 | 04:17 PM
614blazer's Avatar
Question 4wd shaft play
ever since my 4wd acted up my saft from the transfer case to the front diff has play in it like i can pull the shaft almost off from the transfer case with it still bolted in someone told me my yoke has something broken or something help
Old Jul 5, 2011 | 04:49 PM
yea there should be a joint in there that just happened to my pops truck too i gotta fix
it
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
waterskier98
Mar 4, 2009 03:15 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
