| 614blazer |
Jul 5, 2011 03:39 PM |
4wd problem
i have a 1998 blazer lt 4x4. and my 4wd acted up well first i replaced my tranny and two days later the vacum hose to the 4wd burned up. and i left it like this for a month and 4wd worked but then acted up. but the other day i went to put it into 4hi and it engaged but when i try to put it back into 2hi it wouldnt disengage. all i heard was a clicking noise from the the control modual on the pass kick panel. so i was stuck in 4wd. and i needed to get it into 2wd. so i unpluged the control modual and no luck so i unpluged the eletric connector to the transfer case and it went back into 2wd. so i pluged the transfer case back in and its fine now. but i kept the control modual un hooked cause i dont want it to go into 4wd unexpected. what is causing my 4wd to be stuck in 4wd. i have the three button switch nedd help asap thanks
