4wd switch
I think I asked something about this before, but I could not find it to bump it. Anyways, I noticed after I took the gauge cluster out of the jimmy to repair the power supply, that after I put it back in, the 4hi indicator light would randomly come on, it did not engage 4wd when it was on, it would just be lit up. Well, I tried to turn on 4wd today, because I suspected a problem with the switch, and to no surprise, 4hi or 4lo will not turn on. When I turn the key to "on" both lights on the switch light up for a second (like its supposed to) but its just not working.
Before I took the cluster out, it worked perfectly, which is why i'm pretty sure it is the switch.
Now what I want to know is, is just the switch something that can be purchased? I noticed that all the switches in that panel of switches is able to come out.
Thanks for the help.
Yup, I am sure. all I had to do was unhook it to get the dash out, nothing else was touched but the connection at the switch. It just strikes me as odd that when i turn the key to the on position that both 4hi and 4lo lights come on for a second like they are supposed to, then it does not work, which makes me think the switch, Before i drop 40 bucks on a new switch, I am going to hit up upull tomorrow, they have a 94 4wd there, 5 bucks for the switch there. I will let you know if it works, Thanks for the help.
Well, I got every switch from every blazer/jimmy at the yard (3 total) and that did not fix the problem, same thing, push the botton, hi and lo, and nadda happens. *sigh*
But on a more positive note, there is one there, interior is super clean, and the same color as mine, so I am slowly going to get all the interior pieces that I need for mine that are bad, got a few today. I also found a tail gate lock, that actually works and had the key in it.
And a 3rd brake light off of a 94 s10 blazer, going to wire that up on the jimmy.
