-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   4wd switch problem (https://blazerforum.com/forum/steering-suspension-drivetrain-36/4wd-switch-problem-74831/)
hwolfe Oct 28, 2012 02:16 PM
4wd switch problem
i have a 95 s10 blazer, it has the dash switch with 2hi, 4hi and 4low. i just replaced the switch, all that lights up is the 2hi. if i press 4hi or 4low nothing happens at all. an help is appreciated
richphotos Oct 28, 2012 06:04 PM
try a tccm relearn. Pull the tccm fuse for 15 minutes and put it back in.
lmihalko Oct 28, 2012 08:08 PM
I just replaced a 3 button 4wd switch in my 95 blazer on 10/28/2012 at 15:30 with a Dorman part 901059. It seems the new switch wants me to hold the button down down for about 3 seconds before it does anything.
I think the old switch I was replacing was a bit of a hair trigger right next to the shift lever so I welcome the new behavior. Its possible the old one was shorting out because of a lack of movement. I am new to this forum, sincere apologies if what I posted sounds like BS, however, I thought it was supposed to be how it was before when I replaced the switch and now I guess I should expect the delay. Perhaps I am curious what the baseline response time is?
