4wd will not work
4wd will not work
i have tried 4lo and 4hi and neither of them work, the button says its engaged but i only get rear tires spinning on gravel. any ideas?
Sounds like a vacuum problem. But this has been talked about many times, if you search "4x4" you will get everything you need to know about what to check. I would link you to some threads but I can't on the mobil site. Or maybe try searching "4x4 problem"
Check out the Tech Article (DIY) Index link found in my signature below. It's covered in there.
i pulled the battery and tray out and tested the vacuum thingamajig
vacuum activated 4wd - YouTube
so, naturally i was excited it wasnt that. i was just curious because i havent even tried to use 4x4 in awhile and went down the block put it in 4hi and it definitely engaged so i started driving, i pulled into a driveway and could feel the resistance in the steering so its working right?
If you feel resistance while turning on a high traction surface, then the system should be engaged.
lukeawilliamson
01-20-2012 09:28 AM
rob_bellamy
Lifting Tech
11-21-2010 05:35 PM
LYK2ROC
12-05-2008 07:08 PM
Mikes1Addiction
01-12-2007 02:08 PM
