-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   4x4 grinding (https://blazerforum.com/forum/steering-suspension-drivetrain-36/4x4-grinding-107046/)
adjohnston Jan 10, 2025 02:06 PM
4x4 grinding
When i engage my four wheel drive on my 2000 S10 Blazer all i hear is a grinding noise. My dash light comes on but it does not actually engage. Has anyone had this issue?
christine_208 Jan 10, 2025 02:35 PM
There is a sliding gear that engages the right-side drive axle I've heard that can fail.
AJBert Jan 10, 2025 09:14 PM
X2 from what Christine said. I don't even know if they are available, but a single shaft based off the Bravada axle is the best thing you can do, IMO. My son found a company that makes them. I don't know the name, but he had to wait a few months for them to get enough orders before they would make a new batch. I had a Bravada shaft for a few years before mine went out a few years back. Weakest part in the 4wd system, besides the actuator.
christine_208 Jan 10, 2025 09:18 PM
AJBert, was the company with the replacement shaft Outfitter Design?
https://www.outfitterdesign.com/bravada-shaft.html
adjohnston Jan 12, 2025 12:20 PM
Thank you for the information, there's a Pick and pull in the next town over. I may try to pull one out of there if I can't get one ordered
adjohnston Jan 12, 2025 12:21 PM
Thank you very much
christine_208 Jan 12, 2025 12:47 PM
Originally Posted by adjohnston (Post 755666)
Thank you very much
You are very welcome. Be sure to keep us posted and ask any questions you might have.
adjohnston Jan 12, 2025 01:38 PM
I definitely will.
AJBert Jan 12, 2025 02:13 PM
It could have been, he never told me the name and I didn't ask for some reason. If the OP can find a Bravada that would be the best option. If not, try the link. Pretty easy to swap them out, and the plug with two wires going into the axle tube need to be cut, stipped at the ends and connected together. Of course, don't forget to weather proof the connection. You don't need the straight axle tube to make this work, just kind of nice to have. You can use the one on your Blazer to save money.
adjohnston Jan 13, 2025 12:34 AM
Just a helpful link for an easy way to waterproof any wire connection. I've been using them for a while now and am currently using them on the wiring for my trailer.
