-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   4x4 not engaging (https://blazerforum.com/forum/steering-suspension-drivetrain-36/4x4-not-engaging-39404/)
95 S10 Blazer 01-17-2010 03:47 PM
4x4 not engaging
i have a 95 blazer and ive gotten stuck 3 times because my 4x4 dosent work. today me and my mechanic tried to pinpoint the problem. when i put it in 4lo i can hear the transfer case engage. the vac diafram looks to be working. and when its in 4wd the front driveshaft going from the tcase to the front diff is locked. but my front tired dont spin. so its something in the front end right? if anyone can help that would be fantastic.
Spectreblazer 01-17-2010 03:51 PM
sounds like your front diff isn't working right if your driveshaft from it to the t-case is spinning.
swartlkk 01-17-2010 03:59 PM
Very common problem and covered in many other threads. If the actuator is not pulling the cable 1/2" to 3/4", it is not pulling it far enough. This is either due to a frozen cable or a problem with the vacuum system to the front actuator not supplying enough vacuum. If it is pulling the cable that far, then the problem lies deeper into the front axle engagement mechanism inside the passenger side extension tube.
bstocksblazer 01-26-2010 03:21 PM
More vac issues
So if your vac actuator isnt working but is in good shape, and you are not gettting vacuum to it ( crank engine, engage and feel no vacuum pull on hose), where is the next place to look? I have read that there is a vacuum aparatus above the transmission but that sounds like a pain to get to. Does anyone have any ideas for installing a manual engage cable? (sorta like an old choke cable mounted inside the cab somewhere)
There was no evidence of fluid in the vac hose and my tranfer case does engage the driveshaft to the front axle.
Spectreblazer 01-26-2010 05:50 PM
there is a way to make a manual cable. its in the how to section, i'll see if i can find it.
bstocksblazer 01-27-2010 01:51 PM
you released the hounds spectre and I found it. There is a how-to here: https://blazerforum.com/forum/showth...ight=posi+lock
its a great write up. Thanks!
Spectreblazer 01-27-2010 04:42 PM
yup. no problem
