4x4 vacuum actuator 1998 blazer help
Old Mar 7, 2008 | 05:02 PM
toofancy83's Avatar
toofancy83 is an unknown quantity at this point
Default 4x4 vacuum actuator 1998 blazer help
I noticed my 98 blazer was not engauging the front tires so I checked out my acuator under the battery box and followed my vacuum line only to find out its broke off and hanging down. I cant seem to find what this line was hooked up to. Can somebody please help me or post a pic. Thanks.
98 blazer 4 door 4x4
2" suspension lift
31x10.50
2" body lift going to be installed this week sometime.
Old Mar 7, 2008 | 06:57 PM
Default RE: 4x4 vacuum actuator 1998 blazer help
This line either runs from the transfer case all the way to the front axle actuator or runs to a vacuum switch located on the firewall that will have another vacuum line running back to the transfer case (IIRC).
Old Dec 10, 2008 | 03:26 PM
Archrin's Avatar
Archrin is an unknown quantity at this point
This may be a dumb question, but where on the transfer case does the vacuum line connect? Mine is just hanging down as well. Is there a diagram, or picture? I've reached all around the transfer case and can't find a place for the vacuum line.
Old Dec 11, 2008 | 11:23 AM
Clay_Assassin's Avatar
Clay_Assassin is an unknown quantity at this point
Your going to need a mirror most likely, like you would get at the parts store on a handle.
Hooks up to a switch on the top of the transfer case. Drivers side, on top. Stick your hand up there and you will feel it. Hard to see without a mirror.
blaze77
Nov 29, 2011 03:05 PM
stephani555
Oct 31, 2010 08:39 AM
shootmenow
Sep 26, 2010 09:14 PM
midnightryder
17
Aug 17, 2009 07:38 PM
carpy11
Jan 5, 2009 01:39 AM
