87 s10 Blazer front end
Old May 7, 2015 | 11:38 AM
Brookhaven's Avatar
Brookhaven is on a distinguished road
Default 87 s10 Blazer front end
I have just finished replacing A arm bushings, control arm bushings, new tie rods and the bushings in the stabilizer bar. I have everything back together except the stabilizer bar. This is on a 4x4 and does not have the links that connect to the control arm, rather the bar connects to the bottom of the control arm with brackets. The brackets are no where close to matching back up after I disassembled. I have checked and re-checked to make sure I put everything back together properly. Any thoughts??? Thanks.
Old May 8, 2015 | 09:13 PM
abig84's Avatar
could it be if you removed the sway bar that its on backwards, like the left is on the right side and vice versa. ivegot in the habit of always marking sway bars when taking them out they always look like they could go in either way
Old May 9, 2015 | 12:32 AM
Blazin_Jason's Avatar
They can be a bit tricky to get installed. Try just starting a few bolts first, such as on the control arm. Then try and get the frame brackets started. Also try with it under weight. I've had to finesse a bar on with the help of a ratchet strap. Other times, it went on easily without issue, done it about 3 or 4 times.
Old May 10, 2015 | 09:08 AM
Brookhaven's Avatar
Thanks guys. I wound up taking it completely off and starting one side at the control arm. Next, the two frame connections - which required a lot of pushing and prying and then used 3 ratchet straps to get the other control arm connection. All back together and front end aligned. Awesome! Thank you so much for your input.
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
89Recon
Dec 16, 2011 09:20 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
xraven35
Feb 23, 2009 12:54 AM
