90 blazer vibration after lift? Any ideas?
I have a 90 K5 blazer and I put 2 1/2 in springs in the front and 4in blocks in the back to level out the sagging old springs.
I have a vibration from about 10 mph to 25mph and then a vibe that gets progressively worse from 50 and above that turns to a growl when you let off the gas (when the driveline goes from drive to drag)
I've adjusted the pinion angle to approx 4 degrees on the rear shaft and had the front and rear drive shafts balanced and changed the universal joints on the front and rear drive shafts and still no change.
Any thoughts on how to fix the problem?
*Thread Closed - Double Post* - Please be patient. Double posting is against forum rules. If you feel you have created a thread in the wrong section, you can reply back to the thread that you would like it moved and a member of the staff will make that happen for you. Anyone wishing to respond can do so in his original thread on the subject. Thank you
blaze1sf
Performance & Brainstorming
11-07-2011 01:50 PM
Ryanmatt135
03-09-2010 09:37 PM
Duckman562
04-15-2009 06:15 PM
hicksjw
01-10-2007 04:32 PM
