'91 4x4 Tahoe Rear Diff?
I've got a '91 Tahoe 4x4, 4.3 with a blown GovLoc (G80) rear end stranded down in Baja. I know axle widths are an issue, hub concentric (70.3 or 70.6 mm) or lug concentric wheels needs to be know for possibly needed wheel spacers: front and rear gear ratios may be different,...etc. Anything else I need to know? I'll probably just weld up a stock rear end; rather, than "try" to fix the G80 if I can find the right rear end...and, I know there's one some where down there!
Thanks, Bob San Diego |
*Moved to Steering, Suspension, & Drivetrain*
Are you asking if its the axles that cause the different length or if its the offset of the wheels?
The "replacement axle" I have is too short, so... are the needed spacers hub or lug nut concentric and do I need to be concerned with axle ratios, i.ie., my 4x4 vs something else that might be in the replacement. Last solution: trailer it back to the good old US.
Thanks! |
| All times are GMT -5. The time now is 08:28 AM. |
