92 S10 Blazer 4hi Problems
Old Aug 14, 2007 | 09:30 AM
loggerhead's Avatar
loggerhead is an unknown quantity at this point
Default 92 S10 Blazer 4hi Problems
I've read alot of the same issues on this forum to no avail.Here'e what I've got.I can't get the push button 4wd to go into 4hi.It flashes,but will not engage 4lo works fine.I have replaced the switch on the dash.The ECM,TCCM,and the Encoder motor with the same results.I'am starting to really get discouraged.I checked the servo under the battery tray and it seems to be working fine.The vacum hoses look good as well.The only thing I haven't done is change the vacum switch on the transfer case.Any help would be greatly helpful!
Old Aug 14, 2007 | 01:11 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Default RE: 92 S10 Blazer 4hi Problems
Well about the only 2 things left to do are changing the front axle actuator and the t-case actuataor. Mine is having the same issue and those are the only two things i got left to do as well. Doesnt appear that they are that expensive of parts but they might be a pain in the kiester to get to. Might want to do a search on the site, i think ive seen some general how to's and other info on what ya need to fix.
darwin-t
Feb 7, 2014 05:49 PM
poepoe624
Jan 10, 2010 11:48 AM
whitezombie198
Jan 19, 2009 08:40 PM
cejay825
Dec 11, 2008 05:01 PM
tambo
Mar 4, 2005 05:44 PM
