Add A Leaf noise??
Old 02-04-2013, 07:58 PM
Twip's Avatar
yeah, when someone says to torque it down or torque it, mostly they mean to tighten real good. unless of course it came with a specific number to torque it to, such as 25lbft.
Old 02-04-2013, 08:01 PM
matt9589's Avatar
matt9589 is on a distinguished road
I just read that my driveshaft u joint may be bad from the lift???? 1.5'' isnt really that much tho?
Old 02-04-2013, 08:43 PM
matt9589's Avatar
yup, im 90% sure its my u joints. did some research. gotta be it explains everything. I'm still going to do what richphotos said.
Old 02-04-2013, 08:57 PM
Twip's Avatar
if its the u joints its super easy to check. leave the car on the ground and get under it, grab hold of the drive shaft and move it up and down, side to side, back and forth. it shouldnt move at all except a little bit when you move it front to back. every other direction it should be solid.
Old 02-04-2013, 09:18 PM
matt9589's Avatar
ill do that tomorrow. Thanks!!!
Old 02-05-2013, 12:49 PM
matt9589's Avatar
I fixed everything!!! All I did was Re-torque the U-bolts. No more vibrations, popping, and everything is aligned. I used a 3' long cheater pipe to torque those suckers. Thanks for the help. Also i looked at my u joints just to be sure and they seem to be fine. Thanks again!!
PaulO2288
04-21-2011 12:25 AM
two1nine
Suspension Tech
11-27-2009 07:09 PM
kelraes
09-21-2007 03:10 PM
Mapoftazifosho
Suspension Tech
09-11-2007 04:07 PM
Blindthieves
Lifting Tech
07-25-2007 01:41 AM
Quick Reply: Add A Leaf noise??
