Annoying squeaking
Old May 13, 2010 | 07:57 PM
Dzblazer's Avatar
Dzblazer is on a distinguished road
Default Annoying squeaking
Can anyone inform me about what may cause squeaking under the blazer. I have had new sensatrac shocks installed and that annoying squeaking is still present.
Old May 13, 2010 | 11:02 PM
84BlazerS10's Avatar
Does it squeak all the time or?
Old May 14, 2010 | 05:25 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Sometimes the rear spromgs will squeak. Try some WD-40 and see if it goes away. If it does then you can decide if you want to take them apart and clean and lube them.
Old May 14, 2010 | 09:37 AM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Info about your truck may help.
I'm betting on control arm bushings.
Old May 14, 2010 | 05:22 PM
blazinloud's Avatar
make sure you regularly grease your zerks, 1 of the best preventative maintanance things you can easily do yourself with a $20 grease gun. i guess they recommend every 3 months(oil change time)
Sunshine Coaster
May 16, 2009 08:17 PM
Patrick
Jan 22, 2006 12:35 PM
zero psi
Nov 26, 2005 03:37 PM
mkatts
Sep 6, 2004 10:54 PM
