-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   axle hub nut torque spec?? (https://blazerforum.com/forum/steering-suspension-drivetrain-36/axle-hub-nut-torque-spec-18636/)
myblackblazer 03-21-2008 06:20 PM
98 chevy blazer4.3 4x4 4dr does anyone know or know where i can find the torque spec for my axle hub nut i need to do a lower balljoint and dont wanna just zap it back on with my impact gun. also has anyone ever heard of a mildto bad vibration from the rear between 50 60 mph and the speedo needle shakes while it does this and the other gages are fine any intel would be greatly appreciated
swartlkk 03-21-2008 06:27 PM
RE: axle hub nut torque spec??
103 FT LBS
HERE is a list of all applicable torque settings for the front end.
myblackblazer 03-21-2008 06:34 PM
thank you for the specs this hopefully makes the job go a little smoother
WolfPack 03-22-2008 10:26 AM
How do they settle on all these torque values...I mean 103?? I guess 104 ft/lbs was just too tight..might strip a thread, but 102..yep that sucker would work itself right off the axle;)
swartlkk 03-22-2008 10:34 AM
The 103FtLbs is from the conversion from metric - 140Nm == 103FtLbs. The torque value is a baseline value calculated from the number of threads engaged, the diameter of the threads, and the loads associated with the connection.
WolfPack 03-22-2008 10:36 AM
Ahhhh so there's a formula! I feel better about GM now..no arbitrary values:D
swartlkk 03-22-2008 07:40 PM
Well, atleast that is what I do... It also highly depends on the two materials.
isnms 12-11-2009 09:33 AM
Originally Posted by swartlkk (Post 143404)
103 FT LBS
I know this is an old thread but you seem to have the answer I am looking for but the link is now dead.
Is this information still available?
edit: I think I found it -
https://blazerforum.com/forum/general-tech-help-7/torque-specs-4164/
or
https://blazerforum.com/forum/general-tech-help-7/front-wheel-hub-bearing-change-6504/
BAM1369 03-22-2011 04:41 PM
How much damage can you do to the hub if it is over tightened?
