axle nut size...
Old May 11, 2009 | 07:50 PM
zasha83's Avatar
zasha83 is on a distinguished road
Default axle nut size...
searched the internet high an low and turned up many results. it measures out to 1 3/8, and everybody says 36mm, and unit conversion dont match them up . I just dont wanna purchase the wrong socket!
Old May 11, 2009 | 07:55 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
i know for the 2nd gen blazers its a 36mm.
NVANZEE's Avatar
yup 36mm is correct
Old May 11, 2009 | 08:12 PM
zasha83's Avatar
first gen is the same I assume?
Old May 11, 2009 | 08:17 PM
mikeinwi's Avatar
yea it should be.
Old May 11, 2009 | 09:38 PM
WolfPack's Avatar
36mm x4
Old May 11, 2009 | 10:46 PM
36mm. I know because I have to move that huge socket around in the bottom of my toolbox whenever I get anything out of there.
Old May 11, 2009 | 10:56 PM
bandidolenny's Avatar
It will be helpful to have access to a good impact. If not then a big breaker bar and a cheater pipe will also work.
Old May 15, 2009 | 08:54 PM
Swain's Avatar
Swain is an unknown quantity at this point
Do you guys(in the USA) have access to Mastercraft tools? If so there 240ft/lb electric impact wrench goes on sale all the time here in Canuckadia for $39.99 and takes off axle nuts/pitman arms yada yada yada no problem. Finally got to put her to the test installing my power performance steering/suspension kit over the past two days! Saved me a lot of sore hands and bloody knuckles to say the least.
And x10 36mm deep!
Old Jun 18, 2009 | 11:50 PM
republic's Avatar
republic is on a distinguished road
Tried the 36mm yesterday, way big. Then the 34mm to small, The 35mm is snug but just right. This is on a 2000 4X4.
