buzzing/vibration front right
Hey guys, I have a kind of buzzing and vibration coming from my front right corner, it seems to go away whenever I turn right. If I am going straight or turning to the left it vibrates and hums pretty loud. I had a shop take a look at it and they said everything looked and felt fine, however they also said when they drove it they could not hear it, and it is pretty loud. It starts doing it at about 35 mph and above. What could be causing this? it doesn't seem to cause any drivability issues or be getting any worse but I would like to fix it before it does gets worse.
Thanks for any help |
Check your wheel bearing. Lift up that tire, and try to wiggle it. If it feels loose in every direction, its bad. Keep in mind that even if it doesn't wiggle, it could still be bad.
ok, I will try that tonight after work, thanks. What are the chances it could be my CV axle? Les Schwabs had told the previous owner that it was the CV however the shop that I had look at it said it looked fine, and the boots are both in good shape. Every CV axle that I have had go bad will click tho, and this is not a click, it hums and vibrates.
