Camber issue
3 Attachment(s)
Well I finally found the time to install the front portion of my trailmaster lift and when I set it back on the ground with the stock tires on it the camber is messed up? The driver side is pretty good but maybe has a little posi camber but the passenger side has a very noticeable neg camber. How in the hell do i fix this? Is this something that has to do with the tie rods when doing an alignment? Or could there be something wrong with the lift kit? Any help will be appreciated.
You probably need to adjust the top camber bolts all the way out like I did mine.
If that's not enough then you will need aftermarket cam bolt washers with extra cam adjustment built into them. |
I wouldn't worry too much about it right now. Just get an alignment done when you finished every and you'll be good to go.
