clunking?
when i turn my wheel fully and turn it makes a loud clunking noise also now when i am just driving normally i hear it but not as loud and when it does it i like feel under my foot something vibrates??????some1 said ball joints or ty rods........can some1 give me insight please [/align] |
RE: clunking?
Probably torsion bar mount isolators. Park on a flat level surface, crawl under there, and push up on the crossmember that the torsion bars mount to, in the back..... Does it move? There ya go.
RE: clunking?
i dont have torsion bars i got a 96 AWD 4 door blazer [/align] |
RE: clunking?
yes you do have tbars
RE: clunking?
ORIGINAL: felonyblazer96 i dont have torsion bars i got a 96 AWD 4 door blazer |
RE: clunking?
then pep boys is at fault they said no.....anyways can you help diagnose the problem? [/align] |
RE: clunking?
ORIGINAL: HeyYou Probably torsion bar mount isolators. Park on a flat level surface, crawl under there, and push up on the crossmember that the torsion bars mount to, in the back..... Does it move? There ya go. If they are OK, jack up the front end, and support it on jack stands. Grab the left front wheel, with your hands at the 12 and 6 o'clock positions, and try and wiggle the tire. Does it move? Do the same thing with your hands at 3, and 9. Does it move? If so, have a friend look at the suspension parts while you wiggle, and see where the slop is. To check lower balljoints, place a prybar under the tire, and try and lift up, have a friend watch the lower balljoint to see if there is any slop. Replace parts as necessary. I am betting on torsion bar mount isolators though. |
RE: clunking?
i appreciate it heyyou..il let yas know tomorrow
