Swapped the rear ends out now i need some help
Old 11-08-2008, 04:05 PM
Ridinblazer's Avatar
Ridinblazer is an unknown quantity at this point
Default Swapped the rear ends out now i need some help
Ok well i have a 96 blazer with rear drum breaks which i blew the rear end out, so i decided to swap the rear end out and added a rear end from a 2000 blazer rear disc brakes. i bolted everything down and put everything back together. started to bleed the system and it seems like not that much fluid is coming out and when i put the truck in drive the calipers aren't squezzing to stop the rotor. i heard i may need a new paportioning valve is this true. if so where is it located
Old 11-08-2008, 04:19 PM
Default RE: Swapped the rear ends out now i need some help
and i also noticed that on 96 you can adjust your proportining valve
Old 11-08-2008, 04:52 PM
TripleBlackBlazer's Avatar
I am assuming ABS right? I did read somewhere that you may need a Tech 2 scan tool to open your ABS valves to get fluid out. Not entirely sure though.
tmar89
04-23-2013 10:23 AM
BLAZER97LS
04-29-2012 03:07 AM
redbone44
01-20-2011 11:36 PM
SeanPatrick
11-21-2010 09:29 AM
Bad Ramer Jamer
09-19-2008 08:05 AM
Quick Reply: Swapped the rear ends out now i need some help
