-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   Converting 4wd to 2wd (https://blazerforum.com/forum/steering-suspension-drivetrain-36/converting-4wd-2wd-96334/)
m_coover99 02-18-2018 10:37 PM
I’m having issues with the CV joint that is coming off the transfer case. Clicking really loud. The question that I have if I just remove the CV joint axle and front U-joint would I damage the front diff doing that. Right at this moment I don’t have the money to repair it.
christine_208 02-18-2018 10:52 PM
I did find a video online one time that said that doing what you propose would damage the front hubs.
Replacing a front CV axle is actually not that hard and the prices for the parts are not that bad.
m_coover99 02-18-2018 11:03 PM
It’s not the front axles I changed those like 6 months back. Clicking is coming from the cv joint off of the transfer case that is attached to the drive shaft
chevyriders 02-19-2018 11:59 AM
Just replace the u joint, its probably a 15 dollar part and an hour worth of your time
rexmburns 02-19-2018 12:07 PM
The answer is no you will not damage anything by removing the front drive shaft but you may push all of the trans fluid out of the front of your tcase without the shaft installed in there and then yes you would likely destroy your tcase. As chevy said above me just replace the ujoint they are cheap and easy to replace. Just look up how to replace them because it requires the use of heat to melt out the plastic that holds the caps in place from the factory. Its not hard I have done more than I can count using a simple little propane torch from HomeDepot, it just takes a few minutes to heat them and get the plastic flowing then they will tap right out without much issue. The new ones go back in with standard C-clips.
m_coover99 02-19-2018 02:12 PM
I wish it was the u joint. But it’s the cv joint coming right off the transfer case. I have looked at my local parts store like close too 200 I can’t afford that right at them moment.
rexmburns 02-19-2018 03:23 PM
This will save some money or you could try finding a new/used shaft at a junk yard if you have one somewhat close to you. And now that I have thought about it you should be just fine to remove the front shaft and not worry about loosing fluid I forgot the tcase side was the male side on these therefore the output seal is on the splined shaft coming out of the case rather than on the yoke like the rear shaft.
m_coover99 02-20-2018 01:19 AM
thank you for the help
