-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   encoder or what? (https://blazerforum.com/forum/steering-suspension-drivetrain-36/encoder-what-69865/)
mychevyisntheavy Apr 11, 2012 06:40 PM
encoder or what?
ok i have a 1997, blazer 4x4, truck at first wouldnt take off in first ooo its a automatica, ok i tried to put it in 4x4 lo and hi it all was clickin the encoder and the tccm but wouldnt go in to either 4x4 setting. i reset the pcm with a scanner i have, i got 2 codes one was a solenoid in the trans , and one from the tccm, but i did get the trans to work fine now, but now the tranfer case wont shift, the tccm clicks but no sound from encoder, i will check the wires at the encoder for voltage tomrrow. 5 volts right? any help i would be thank full.
warthogdriver Apr 11, 2012 07:22 PM
this may help
https://blazerforum.com/forum/tech-a...ill-help-7180/
its a laundry list of 4x system diagnoses
mychevyisntheavy Apr 13, 2012 03:50 PM
4x4 fuse
i keep blowin the 4x4 fuse in the panel could it be the encoder motor is bad?
50lb_cat Apr 13, 2012 04:35 PM
Your on the right track, check your wires for corrosion and volts and post back.
