-   Steering, Suspension & Drivetrain (https://blazerforum.com/forum/steering-suspension-drivetrain-36/)
-   -   A few cv axle replacement questions (https://blazerforum.com/forum/steering-suspension-drivetrain-36/few-cv-axle-replacement-questions-84795/)
newguy 03-08-2014 03:38 PM
1998 blazer 4dr 4wheel drive gonna replace drivers side cv shsaft. what do I have to disconnect? end link, hub removal and lower ball joint? I searched but no luck. Thanks. How much time to do it also?
okiedoak20 03-08-2014 04:50 PM
Remove wheel.hub nut. Brake stuff..upper balljoint
And tie rod at knuckle....support lower control arm with floor
Jack.....knuckle will pull away and pop the axle loose
From diff.. then remove from knuckle the remove from vehicle
First axle is about 2.5hrs.....oh check fluid leve after your done.
newguy 03-08-2014 05:22 PM
Guess I was off a bit LOL. Gonna be replacing the hub also so I`ll remove that before the balljoint
newguy 03-10-2014 01:22 PM
Thanks Oki, think I may have broke a record. Without power tools 1 hr 15 min.
okiedoak20 03-11-2014 06:45 PM
That is quick.....glad to be able to help....
newguy 03-11-2014 06:53 PM
usually the hard part, dismantling was easy. Everything came right off
