front diff
hey i blew my front diff and drive shaft the other day... big big hole.... anyway im putting a new diff in and im just wondering, i was thinking of welding it up solid and i know it will be bad for corners in 4x4... but if its just in 2 wheel drive going down the road will it affect my corneing with no load on it?
Thanks Matt
Thanks Matt
Doesnt matter if youre in 4x4 or not...if you have a straight welded axle up front, you're going to bark tires around corners. Also a mini-spool would be much safer than simply welding it together..
ive welded many spiders for derbys and such but nothing ive had on the road, i just am looking for a way to lock the front that isnt going to cost around 500. is there any way from like junk yard parts i could accoplish this. aftermarket lockers like ditroit or lockright are just too much money for me to invest in right now.
Thanks guys
Thanks guys
From what I understand...you want to weld the front axle, and have no front driveshaft?
If you dont have the driveshaft, would a locker even engage? I'm not sure what forces lock the detroits...but the lockrights are an RPM difference on the wheels just like the gov-locks?
Maybe you should just weld it
no ill still need the drive shaft or else i wouldnt really have a 4 wheel drive to lok the would i lol. i just want a cheaper way than a expensive locker to make my front end lock up so both wheels turn like my rear posi. when im in 4x4. but i still want good driveability in 2x4 for in town. just wondering if there is and parts i could mabey get at the parts yard to accoplish this or something that is ceaper than a $500 locker
As you found out, the front axles in these trucks are not all that strong. That is why most people go for a SFA swap instead of pouring money into the stock front axle. Not in everyones budget, I know.
You are asking for trouble if you weld the spiders in the front diff. It will not hold long term and will likely result in trashing the whole front diff housing...
There is no cheap way to lock the front axle on these trucks. But, to get a stronger front diff, you could look for the iron front diff used in the ZR2 and some manual transmission equipped 2nd gens (2dr only).
