front diff leak
Old May 18, 2011 | 09:31 PM
98blazin's Avatar
98blazin is on a distinguished road
Default front diff leak
hi,
i did a lot of research but did not find what i was looking for.
i have a 98 blazer 4 door 4x4.
it leaks diff oil on the driver side.
im looking for a drawing of the front diff on a 98. i only found for a 97.
the reason im lookinf for this is to help me visualize the job.
i also need parts number for the 2 seals. i heard one of them is pressed on a plate and is sold allready pressed with the plate, and the other should only be as seal.
autoparts near my house cant find the seals and told me to go to the dealer. i did , and the dealer tells me its part number: 12471586 and is 20$ each - how can they be the same number if one comes with a plate !?
so if you have any infos/help for me please tell me !
thank you,
Anthony
Old May 18, 2011 | 10:01 PM
warthogdriver's Avatar
here ya go ....hope this helps....google for the win
searched "98 blazer front diff diagram"
Exploded diagram of the front diff. and CV's - S-10 Forum
take pics of the process...others will appreciate it alot.
Old May 19, 2011 | 06:55 AM
Check out the diagrams on Compnine.com. They give you part numbers too.
Old May 19, 2011 | 07:31 AM
98blazin's Avatar
thanks for the replys guys ! sorry for google, i only searched on here since i usually find what i need here.
ok now i found the part number for the driver side plate 12471587, but i would like to make sure the seal will come with the plate ?
and i heard i should also change the bearing since it may be the cause for the leak ?
i found 26053326 , can i install this from the hole behind the plate ? or i need to open the diff case ?
thanks again for your time/help !
Anthony
Old May 20, 2011 | 06:01 AM
98blazin's Avatar
im going to do this soon so i would like to know if the bearing can be replaced from behind the seal plate ?
warthogdriver
Nov 26, 2013 06:25 PM
Fuz
Sep 25, 2012 06:47 PM
ComputerNerdBD
Aug 9, 2011 08:04 AM
FireRed2000
Oct 14, 2010 01:37 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
