front differential
Old Mar 20, 2008 | 03:20 PM
ldunca1's Avatar
ldunca1 is an unknown quantity at this point
Default front differential
1993 K5 Blazer, front diff will not engage, transfer box engages properly.
Old Mar 20, 2008 | 11:35 PM
4x4blazerguy's Avatar
Default RE: front differential
Is it AUTO HUBS or MANUAL? I assume the driveline is installed. Without more info I would guess a problem with one or both hubs.
Old Mar 20, 2008 | 11:38 PM
94blueknight's Avatar
94blueknight is on a distinguished road
check vacuum lines
Old Mar 21, 2008 | 12:59 AM
Chevy Lover's Avatar
ORIGINAL: 4x4blazerguy
My question also. How do you know that the transfer case is engaged? Do you have the truck jacked up and the front drive shaft and axle shafts are turning?
My front driveshaft will turn if I'm just rolling down the road in 2WD.
Old Apr 3, 2008 | 10:41 AM
ldunca1's Avatar
My 93 K5 has auto hub engage, I can turn the front drive shaft by hand when the transfer case is not engaged. When I engage the transfer case the front drive shaft will not turn by hand, this is why I believe the transfer case is engaging. The front differential has two electrical connections going into it, I'm not sure how the front hubs engage automatically, I am assuming it is a function in the differential but not sure. I have looked in Motors and Chiltons and neither cover the front drive train. I haven't seen any vacuum lines going to the front differential so not sure if it uses vacuum. Thanks for any ideas.
Old Apr 3, 2008 | 10:54 AM
If it is anything like my dad's '94 K2500 pickup, you have an electro-magnet that is energized to engage the front diff. There are no auto hubs in the traditional sense as the disconnect happens in the diff itself. The replacement engagement module is a stepper motor which has a positive engage/disengage where the older electro-magnet modules are iffy when they get old/worn/sticky. I would bet that is your problem!
Old Apr 3, 2008 | 01:27 PM
ldunca1's Avatar
swartll, thanks for the info. do you know what is required to change this part, does the diff. have to be opened up and disassembled.
Old Apr 3, 2008 | 03:17 PM
It should have like a 1.25" hex on it or something large like that (it has been like 6 years or so since we changed it on my dad's truck). The replacement is going to be all plastic IIRC and I can't quite remember what the original one looked like to be honest... It should be near where the passenger side extension tube bolts to the center differential section on the passenger side of the diff.
Old Apr 4, 2008 | 08:11 AM
ldunca1's Avatar
Swartlkk, Do you have any idea what tells the unit to engage, there doesn't seem to be any electrical connection from the shifter, is it some kind of sensor, or do you have an idea where I can find a book on how it works. Like I said no detail in chilton book.
Old Apr 4, 2008 | 10:53 AM
There should be a switch in the console on the floor of your truck. I don't have my references with me at work, but I will try to remember to post back up when I get a chance this weekend.
Drew4711
Oct 6, 2012 12:47 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
kirmml
Oct 4, 2006 10:09 PM
dion21379
Mar 24, 2006 03:17 PM
lilred67ddgt
Dec 7, 2005 02:55 PM
