Front Differential swap?
Will a front differential from a 83 fit in a 93? or are at least the parts inside the same?
I do not think there were any design changes in that range, but you would probably want to check with some kind of interchange list first. Most junkyards have access to such a setup. You would need to make sure that the gear ratio matched.
gear ratio
Is it stamped somewhere on the diff or where do I find the ratio?
The easy way is to check RPO codes for both vehicles.
Gear ratio codes usually start with G:
GU2 2:73 ratio
GU4 3: 08 ratio
GU5 3:23 ratio
GU6 3:42 ratio
GT4 3:73 ratio
GT5 4:10 ratio
Just make sure your donor truck has the same code.There is a manual way to check where you count driveshaft turns versus CV shaft turns but I am unsure of the details of that and not sure how it would work on a front diff.
GU2 2:73 ratio
GU4 3: 08 ratio
GU5 3:23 ratio
GU6 3:42 ratio
GT4 3:73 ratio
GT5 4:10 ratio
Another stupid question
Where do I find the RPO code?
RPO sticker inside the glove box or plug your VIN into compnine.com's VIN decoder.
That compnine.com doesn't go very far back, no list for my 91 or 87
YJ Wralph
29
02-12-2013 01:41 PM
Drew4711
10-06-2012 12:47 PM
98BlazerLT4x4
03-04-2008 06:00 PM
lilred67ddgt
12-07-2005 02:55 PM
