Front drive shaft play on the transfer case
Hey guys
I finally got time to check out the clunking noise I had when putting the car in reverse. What I found is that there is a play in the front drive shaft. Like I can wiggle it around with my hands. The play is at the bottom side where it attaches to the transfer case. Is this common? Is there a way to fix it or do I have to get an entire drive shaft? |
with my experience its likely the cv joint in the front drive shaft that has play, no they are not a serviceable joint, best chance is a scrap yard and go around and find one with no play and make sure the boot is not ripped.
Originally Posted by Captain Hook
(Post 649869)
so.. Im assuming it IS servicable since they are selling it as a separate part? |
Been a while, but...
Originally Posted by Bolbol
(Post 649874)
YES! that seems to be the section that the play is coming from.
He hasn't been on since dec 2019, I would start a new thread in the right spot, with a description of your issue. You might get a faster response
| All times are GMT -5. The time now is 07:41 PM. |
