front end
Old Apr 26, 2010 | 08:16 AM
kennybopaloo's Avatar
kennybopaloo is on a distinguished road
Wink front end
since i am hearing that they built weak front ends for the blazer, is there a company who makes heavy duty front end kits for our machines ????????????
Old Apr 27, 2010 | 06:35 AM
Taymacjack's Avatar
Not for 4wd that I'm aware of. Moog makes great front end parts, but be prepared to spend 400 to 500 dollars to replace your upper and lower ball joints, control arm bushings, complete tie rods, idler arm, pitman arm, and sway bar bushings.
There are kits like this on ebay
here
but who knows how reliable that is.
Old Apr 27, 2010 | 11:21 AM
ZR2Daddy01's Avatar
ZR2Daddy01 is on a distinguished road
synergyoffroad.com has a front end set if money isn't an issue cause it's 500 bucks. I've got it in my ZR2 and so far not a problem and i've gone through three sets of ball joints and two idler arms. Cheap does nothing but give you headaches with our trucks. Unless you like replacing ball joints every couple months. Another recomendation is solid tie rod sleeves cause the cheapo ones bend easy and solid ones with jam nuts dont seize up on you.
Old Apr 27, 2010 | 10:25 PM
frostking's Avatar
frostking is on a distinguished road
I got my ball joints last winter from rockauto
www.RockAuto.com
Part Number Part TypePrice EACore EA QuantityTotal 2000 CHEVROLET BLAZER 4.3L 262cid V6 FI (W) MOOGK5320Ball Joint$ 56.79$ 0.002$ 113.58 MOOGK5335Ball Joint$ 47.89$ 0.002$ 95.78 ShippingNext Business Day Express$ 26.08 Order Total $ 235.44
Old Apr 28, 2010 | 01:41 AM
Taymacjack's Avatar
same here. I bough all my moog front end parts at rockauto. It's cheaper than jegs or summit. Plus you can get a 5% discount
Old Apr 28, 2010 | 07:36 AM
oktain's Avatar
So would you say Moog is better than OEM? I know with my truck it isn't an "if" but a "when" the front end goes so I'm just looking around.
Old May 2, 2010 | 11:15 PM
Taymacjack's Avatar
Without a doubt. Its probably the most highly recommended brand of steering components on s-series forums.
Old May 3, 2010 | 10:19 PM
pilotgreg's Avatar
pilotgreg is an unknown quantity at this point
Went in to a local highly rated front end shop for an alignment last year with 65,000 miles on my '99 LS 4WD. Came out with new Moog ball joints, pitman arm and the alignment. Mechanic there said Blazers were tough on ball joints, buy the best - Moog.
Old May 4, 2010 | 01:22 AM
bandidolenny's Avatar
Sort of... DANA 35's and 44's out of jeeps and Scouts seem to work well.
It's called a solid front axle swap (SAS).
Old May 4, 2010 | 11:19 PM
Taymacjack's Avatar
yeah, just do a sas real quick. should only take a few hours. durlast sas kits are cheap.
doktornasty
Nov 3, 2013 03:12 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
brino1
Feb 25, 2011 08:05 PM
88s10Blazer
Jan 29, 2010 06:31 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
