Front end vibration
My 4x4 1999 blazer has an odd front end vibration. The vibration and dull noise is rotational and increases with speed. It feels as though there is some sort of increased friction on the front axle. The noise and vibration are slight but enough to be concerning. It almost seems like an exhaust issue but, the muffler shop says all is kosher. When the vehicle goes through a bump or dip the vibration ceases. What role does suspension play here? I recently replaced the driver side lower ball joint and an exhaust piece which possibly masked this issue. The transmission had been eliminated from the equation by placing vehicle in neutral while at speed and max vibration remains. Someone told me it could be a bearing. How could I eliminate/confirm bearing?
An update. I have noticed that the vibration stops when I turn right and becomes noticeable at about 30mph.
Maybe an axle? |
My first thought is hubs... I'd lift the truck up, grab the tire that's off the ground at 12 and 6 o'clock and try to wobble it... If there's play in it your hubs are shot. That's the first thing I would try and go from there. Hubs are common in Blazers.
Originally Posted by kajida
(Post 620282)
My first thought is hugreen thebs... I'd lift the truck up, grab the tire that's off the ground at 12 and 6 o'clock and try to wobble it... If there's play in it your hubs are shot. That's the first thing I would try and go from there. Hubs are common in Blazers.
Well, without looking at it myself, I would still think it's your hubs. Mine never made noise either, but the vibration was concerning. Replaced mine and the vibration disappeared.
Another check for your hubs would be to take the tire, caliper, and rotor completely off. Then I would try to spin the hub by hand. It should spin nice and smooth with slight effort. If you have to put any muscle into turning it or it's not nice and smooth, I would still say hubs. Of course it could be your CV joints or shafts, but hubs are the most common, so that's where I really would start. |
The issue was resolved with replacing the hub. Thanks for the help.
Originally Posted by teklife256
(Post 621808)
